Preprocessing
Preprocessing
Mesh Generation Taking a Long Time
    • Afrah
      The following shows my dcb specimen. It has a triangular infill I generated using facets
      Here are my mesh settings:
      I also have a face sizing object for the two faces on the front and back of the specimen, and then another for the rest of faces. This is because I need the same number of elements on the top and bottom of the crack interface.
      Even after an hour, the mesh progress is still the same:
      I've completed a simulation with the same mesh settings on a DCB without the infill and it ran perfectly. Now, with the infill, I am running into this issue. How can I fix this (do I maybe just need to wait longer)?
      Thanks in advance!
    • peteroznewman
      The number of faces increased by a factor of several 100 so it's reasonable to have a similar increase in meshing time.
    • Afrah
      I waited overnight for the mesh to generate and it's still stuck "meshing edges (4/4)". Is this normal?
    • peteroznewman
      You can use DesignModeler to count the number of faces or edges.
      Cut your model down by a factor of 100 and see if meshing will complete.
    • farnazhd66
      I have also the same problem with my model. It takes almost 2 days now and still ongoing! I know that it is a complex model but I want to know whether it is normal to take such a long time or not.
      and can you give me some tips on how to reduce meshing time? (mesh resolution is already set to the lowest)
      many thanks,
      Farnaz
    • Afrah
       Yes, that's completely normal I've been having the same problem for a while now.
      I did two things to reduce meshing time. First, as peteroznewman said, I decreased the number of faces in my model, significantly. Without doing so, I also would be running my model for 2 day +.
       Also, use parallel processing if your CPU supports it, this also decreased my simulation time  (I  re-ran my simulation on a computer with 20 cores to parallelize, so it really helped me)
Viewing 5 reply threads
