Preprocessing
Preprocessing
Mesh Generation
    • Siva Pavan Josyula
      Hello Community,
      I am facing problem when meshing my model in ANSYS workbech mechanical.
      I was not able to obtain smooth transition of mesh even after assigning line division to obtain smooth mesh.
      Here I have defined the line spacing and also as mappable face.
      Meshing tree
      But the mesh which I obtained looks like this. with no smooth mesh transition in shell  meshing.
      Meshed model
      in below picture we can easily depict the no transtion of mesh.
      Zoomed in model to show no transtion
      Can anyone help me with this problem?
      Kind regards
      Pavan
    • peteroznewman
      Pavan,
      If you create an Archive of your project, you can attach it to your post above using the Attach button if the file is < 120 MB.
      Where did the geometry come from?  It looks like it is in a multibody part, but some CAD interfaces (like NX) do not create shared topology like DesignModeler does.
      Best regards,
    • raul.raghav
      Pavan, instead of defining the line spacing, can you try defining the number of divisions on the edges. Try to keep it consistent (same) for all the edges and see if that fixes the issue.
    • peteroznewman
      I see two vertex points in the image. One belongs to the grey surface and the other vertex belongs to the brown surface. In DesignModeler, you can split an edge. If you split the edge of the grey surface at the vertex on the brown surface, and split the edge of the brown surface at the vertex on the grey surface, you will have two matched edges (one long and one very short) and setting the number of divisions as Raul suggested on those two edges should force a congruent mesh.
      HI Peter,
      I have imported from NX and its not a multibody part. my model is 3D wind turbine rotor blade.
      In 3rd picture of my Post they are not vertices, but they are nodes and we can clearly see dissimilar mesh between two surfaces in same part. I would like have a amooth transition with the mesh sharing same nodes between two surfaces.
      Is this due to bad geometry cleanup from ANSYS workbench
      Hi Rahul, Line spacing and edge division is same and I have maintained line spacing consistantly.
      My question is not how to mesh, rather if you see 3rd picture in my 1st post, I have highlighted the nodes where you can see dissimilar mesh which is very unsual having dissimilar mesh when two surfaces are sharing common line to a part.
      My basic question is why I am getting different nummber of nodes common line shared between two surfaces to form a geometry?
      Pavan
    • peteroznewman
      Hi Pavan,
      I have a best practice for bringing geometry in from NX. After import, I immediately open the geometry in DesignModeler, then pick the part at the top of the tree and right click to Explode Part. There will be 10 Parts and 10 Bodies. Then pick the 10 Parts and Form New Part. There will be 1 Part and 10 Bodies. Now Refresh in Workbench to update the geometry in Meshing. The Shared Topology should now work as designed and create congruent meshes.
      I do this Explode Part / Form New Part routine at the start of the model building phase since it will break the scoping after BCs have been applied to those bodies.
      Hi, Peter,
      I followed the same process of forming a single part in Designmodeller after importing from NX for the case of geometry cleanup later I have created datums to slice bigger component to form smaller bodies for better meshing.
      Please let me know, if you have any alternative Ideas on this problem.
      Kind regards,
      Pavan
    • peteroznewman
      Add one more slice through the center of the tube slicing all bodies in order to create matching vertex points on the circumference on adjacent edges.
    • raul.raghav
      Could you possibly upload the geometry file or the workbench archive file? It would be interesting to know why the shared topology is not working in your case.
    • peteroznewman
      Recently, I added mesh controls and shared topology didn't work. If I deleted all mesh controls, then shared topology worked.
      Do you get a congruent mesh if you delete all mesh controls?
      I'm also interested to see the geometry. You can attach a zip file or a project archive .wbpz file if it is < 120 MB.
Viewing 10 reply threads
