June 28, 2022 at 12:06 pm
June 29, 2022 at 3:21 am
SubscriberTet mesh this.
June 29, 2022 at 7:51 am
Emperor
SubscriberHi @pertoznewman,
it's a mesh for speed dynamics (centrifugal), so I have to hexa mesh. The corners are complicated but I can make slight modifications.
Do you have any ideas ?
June 30, 2022 at 3:12 pm
Sahil Sura
Ansys EmployeeHi @Emperor,
Try using the Multizone Meshing method, which has a way over sweep meshing. More on that can be found on the links below- MultiZone Meshing (ansys.com)
You might want to adjust the mesh at some locations by using edge sizing, etc., and other mesh controls.
Hope that helps!Thanks,
Sahil -
July 2, 2022 at 10:41 pm
Subscriber@Emperor
What do you mean by “speed dynamics”? Do you mean Explicit Dynamics? I understand that requires linear elements, but the implicit solver used for dynamics problems can work with quadratic tetrahedral elements. The benefit of tet elements is you can get a result quickly with a coarse mesh and very easily refine the mesh where needed. Contrast that with the time you will spend simplifying the geometry and slicing it up to get a hexa mesh, and how difficult it is to refine the mesh later. This is why I recommend a quadratic tet mesh.
3930
2649
1861
1272
610
