October 30, 2018 at 7:10 am
bilgin
SubscriberHi,
I am trying to get mesh for fluid analysis in my model. I couldn't get sweep mesh and inflation. I attach one mesh model and link the project.
The first layer thickness is 1E-5 and the number of maximum layers is 24. Does someone help me?
http://dosya.co/hmdn68k5sk5m/Model.zip.html
Thank you
October 30, 2018 at 2:19 pm
Aniket
Ansys EmployeeHi bilgin,
Ansys employees cannot download the member's model and debug it but if you can add more details to the question and some inline images, we can help you further, or alternatively, you can wait for other users to give you feedback on this. -
October 30, 2018 at 3:37 pm
bilgin
SubscriberHi Aniket,
I can explain how I create the model. I created 2 sketches. It is shown first picture.
Second is shown second picture.
After that I made extrude with depth is 9.63 m. It is shown third picture.
Then I made sweep cut with pitch is 0.32 m. It is shown fourth picture.
Above I explained how I created it. When I open the meshing tool. I got the message is 'The following faces have high order NURBS surfaces. These may take longer than usual to mesh.' So, I created default mesh. I shared the first post. Now, I want to make a mesh with sweep method. Also, inflation around edges in cut skecth(picture2).
What can I do for getting sweep mesh method?
Thank you
October 31, 2018 at 3:43 pm
Ansys EmployeeIgnore the NURBS warning unless the meshing tool chews up the surfaces. However, it looks like you've got a floating face in the domain and this may not be a good idea. Also, do you really need a 3d model as it looks from the image that it's just 2d?
If you need to sweep, look for the tutorials, but you will need to assign sweep mesh type and then inflate that: there will be tutorials if you have a look.
November 2, 2018 at 4:20 am
bilgin
SubscriberActually, I need 3D model because it is the fluid part of system coupling. I will again try to look at the tutorial.
Thank you.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1283
1096
459
