April 20, 2018 at 7:55 am
May 7, 2018 at 11:43 am
Vishal Ganore
Ansys EmployeeCan you share the workbench project file to understand it better?
May 12, 2018 at 9:46 am
Mohan.Karantha
SubscriberHi Vishal,
I can't upload .wbpj file here.Can you share your mail id so that i can share it.
Thank you reagards,
Mohan
May 12, 2018 at 11:23 am
May 12, 2018 at 2:42 pm
Mohan.Karantha
SubscriberPlease find the attached file.
May 12, 2018 at 3:31 pm
raul.raghav
SubscriberMohan, there are no attachments in any of your posts.
May 12, 2018 at 4:23 pm
Mohan.Karantha
SubscriberI tried to upload the files. But it fails.. File has 155 MB. still it fails to upload.
May 12, 2018 at 4:52 pm
raul.raghav
SubscriberUnfortunately, the file size is restricted to 120Mb. Could you upload it to google drive and share it?
May 13, 2018 at 5:36 pm
Mohan.Karantha
SubscriberHi,
Please find the below link for the file.
https://drive.google.com/open?id=1pGg0T-In7aDsu3IwwzL-Cj5VTBOEH-s5
Mohan
May 16, 2018 at 8:19 pm
raul.raghav
SubscriberI copied your Fluent workspace and worked my way in the copied workspace. I opened the geometry to make sure everything was right there and it was. I opened the mesh and deleted the connections and created new connections automatically. I used "multizone" meshing method for the coil and the water inside it while I used a patch conforming mesh for the outer air domain. I then built the mesh focusing on the number of mesh elements (assuming that you have Ansys Student License). Then I opened Fluent setup and I could see the mesh interfaces tab active. Attached is the modified workbench archive file if you want to take a look into it.
The modified workbench archive file: Heat Exchanger
May 17, 2018 at 5:46 am
Mohan.Karantha
SubscriberThank you very much Rahul. May i know which version of Ansys you are using?
Mohan
May 17, 2018 at 3:20 pm
raul.raghav
SubscriberMohan, I used Ansys Student v19.0 when I worked with your files.
5242
3283
2467
