TAGGED: 1d, mechanical, mesh-metric, meshing, roll-cage
December 6, 2020 at 8:33 am
vvishesh
SubscriberI have been doing static structural analysis of my roll-cage (ATV) using 1D mesh. The mesh formed was basically segments of the tube that I have used for my roll-cage. There were no errors during meshing but when I checked the different options in mesh metrics such as element quality, aspect ratio etc, I observed that all of the values were 0 by default. I am unable to understand why did it happen so because when I had analyzed the roll-cage using 2D mesh elements I was able to get non zero values for the same. Can anyone help me out with it?
December 6, 2020 at 3:01 pmpeteroznewman
Subscribern2D and 3D elements can be checked using various mesh quality metrics. There is the concept of an ideal shape, for example a square is the perfect four node shell element shape. As the shape deviates from a perfect square, the mesh quality metrics such as Aspect Ratio and Skewness reduce from their ideal value.n 1D elements are not checked because every element is ideal. A two node beam element is always a straight line between two points.nViewing 1 reply thread- You must be logged in to reply to this topic.
- A solver pivot warning or error has been detected
8762
4658
3151
1678
1456
