Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Mesh Metric Help
    • xiaoling
      Hi, I am confused that my mesh metric indicated none. It should not happen, right? My Ansys version is 18.2.
      By the way, this is the only way to access mesh metrics, right? In the previous version, as I saw online, the mesh metric tool exists in the statistics part, and there should be a list of parameters under it.
      Click on "Mesh" in the tree and then scroll down the list. Note, the panels were redesigned a couple of versions back so make sure you check all the menus.
      You want to look at skew, aspect ratio and (potentially) orthoganal skew/quality (the name varies).
    • xiaoling
      I already checked the mesh menu, but could not find it. Only find it in geometry part, however, it did not give me any informations
    • xiaoling
      I finally got it!!!! Thank you Rwoolhou!
Viewing 3 reply threads
