November 14, 2017 at 2:05 pm
tnegem
SubscriberHi Everyone,
I had a small issue that I do not understand why I have this problem when I am trying to improve my element quality using the mesh metric I get the graph as shown bellow which is very annoying because I can't really understand much of it. How is it possible to get the values of the Y grid(No. of elements) to be presented.
November 14, 2017 at 4:07 pm
November 14, 2017 at 8:36 pm
February 3, 2020 at 11:00 pm
Raghu1013
SubscriberHi guys, i am working on a project and i did meshing in ansys, i want to get a proper matrix of how many of the elements are tetrahedrons, hexahedrons and shell elements. Is it possible to check that in ansys?
February 4, 2020 at 12:31 am
SubscriberOnce you Solve the model, a count of each element shape is summarized in the Solution Output that can be found under the Solution Information folder.
February 4, 2020 at 8:22 pm
Raghu1013
SubscriberThank you for the reply.
I am working on a project in LS-DYNA, is there any way i can convert the ANSYS mesh file to LS-DYNA '.K' format using ANSYS student version. Kindly let me know. Thanks in advance.
Raghu
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1283
1096
459
