Preprocessing
Preprocessing
mesh metrics option in ansys 19.2
    • Bots
      i am a student new to using ansys. i have found some wonderfull tutorials to help me get familiar with the software, however i am currently stuck at meshing. i am not able to find the option "Mesh Metrics" which should be found the statistics tab according to the tutorials.
      does anyone know where to find it in ansys version 19.2
      kind regards
    • Keyur Kanade
      it is just under sizing named as quality as shown in image below.
      if the solves your  question, please mark this post as 'is solution' to help others on forum. create a new post for new question.
    • Bots
      I found it thank you
    • Keyur Kanade
      Good.
      Can you please mark this post as 'is solution' to help others on forum.
    • ayodele1
      I am meshing in Workbench 19.2 and have checked the mesh "skewness". The histogram is rather upside down and is without the axes labels. When I highlight the bars, the affected elements are also not revealed in the model.
      Please guide me on how to properly orient the histogram showing the labels, and the elements indicated on the model when I highlight each of the bars on the histogram.
      Thanks in anticipation.
      Ayodele
    • Keyur Kanade
      increase height of histogram 'window'.
      this will decrease height of graphics window.
      Keyur
    • ayodele1
      Thanks Keyur.
      It worked. How do I mark this as "Is Solution"?
      Ayodele
Viewing 6 reply threads
