Mesh node limitation issue – Need to use fine mesh in the tread surface and coarsed mesh in the rest
March 19, 2021 at 12:20 am
ka423
SubscriberMarch 19, 2021 at 6:12 amKeyur Kanade
Ansys EmployeeYou will need to use different sizing functions. nPlease have a look at nPlease check following videosnnAnsys Meshing,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynMarch 20, 2021 at 12:40 amka423
SubscriberI checked out the video and the meshing done is in CFD not mechanical, which I was using at the moment. also the nodes count are above 60k~120k in the provided method. nif the mesh condition set by me is will work in the full licensed Ansys software that I can try, just need to clarify the condition set is correct or not.nViewing 2 reply threads- You must be logged in to reply to this topic.
2600
2086
1317
1108
459
