Mesh not working (Ansys 2023 R1 Student version)
    • Inaam Hussain
      Dear Ansys Support Team,
      My geometry design modeller for the Ansys Workbench 2023 student version is working fine. But when I open the mesh every time, it's not working,
      as it keeps saying a diagnostic file has been written. A dump file. Could you please help me fix the problem?
      All the best,
      Inaam Hussain
      Mobile number: REMOVED - Rob
    • Inaam Hussain
      Then it says it on here on the student workbench.
      Please resave to a path that doesn't have ( ) in the structure. "Odd" characters tend to mess with some of the tools.
    • Inaam Hussain
       "Please resave to a path that doesn't have ( ) in the structure. "Odd" characters tend to mess with some of the tools. "
    • Inaam Hussain
      Please show me how, Rob.
      Start a new Workbench session and save to a folder that does not have any ( ) or other "odd" characters in it. Or use "Save As" and do the same.
    • Inaam Hussain
      How? I tried it out and renamed my folder without () or any special characters, but it isn't working.
    • Inaam Hussain
      What are you talking about? What do I need to do?
      What error message are you seeing now?
    • Inaam Hussain
      Let me know to resolve this issue ASAP.
    • Inaam Hussain
      This is the error message I'm seeing.
      So, what does the dump file tell us?  How does the geometry look?
    • Inaam Hussain
      For now, the mesh is working but the Ansys fluent software isn't booting up, even with so many computer restarts
      Have you checked any of these threads?  https://forum.ansys.com/?s=failed+to+validate
    • Inaam Hussain
      But which solution attempt thread should I try first?
      Start with the most recent and work backwards.
    • Inaam Hussain
      OK, give me the most recent solution thread attempt and I can start from there
      Did you look at the "order by" options?
    • Inaam Hussain
      It's hard to find
    • Inaam Hussain
      Help me find another solution Rob.
    • Inaam Hussain
      Ansys.Fluent.Cortex.CortexCommandFailedException: An error occured in FLUENT while applying case and settings informatins.
         at Ansys.Fluent.Cortex.CortexCommunicator.SendMessage(String msg, String msgKey, String errorMessage, Boolean waitForReply)
         at Ansys.Fluent.FluentCommunicator.UpdateSetupInfo(Dictionary`2 info)
         at Ansys.Fluent.Data.SetupData.ReadCaseModelInfo(IFullContext context)
    • Inaam Hussain
      A new problem, but how do I solve it?
    • Inaam Hussain
      By problem,I mean this:
      Dear Ansys,
      I am using the 2023 Student version of ansys. The R1, but all of  a sudden, this new problem appeared. How do I fix it?
      Seeing as you've opened another thread I'll leave the Installation specialists to answer that one.
    • Inaam Hussain
      But how do I get started in resolving this issue?
      By looking at the error and then searching for it. By not opening a second thread. I am not repeating work that others have done.
Viewing 25 reply threads
