November 12, 2019 at 8:19 pm
rachels1001
SubscriberHey guys,
I'm kinda stumped on a basic problem. I created an essentially 1-D mesh, of a single pipe. This is just a proof of concept before a larger simulation. The simulation is 1-D, with quadrilateral mesh elements. The mesh was fine, and said that it imported into fluent correctly; however, when I imported it into fluent, it is viewable only as a wire-frame, not the opaque surface that you would normally see [see below].
The mesh imported without warnings and no errors pop up when I check the mesh. The mesh volumes are basically what I would expect when I check the mesh. I have tried playing with the lights and viewing options, but I can't make the surface opaque. Did I import the mesh wrong, or is this just a superficial issue?
Sorry for the basic problem, it's just bugging me a bit.
Thanks,
Claire
November 13, 2019 at 11:51 am
Ansys EmployeeIt's 2d, so there are no surfaces as such. What do you expect to see?
5162
3251
2443
