Mesh Order within the Parameter Set
    • Tim Dietl
      Hello everyone,
      how can I use the mesh order in the parameter set? Or does the mesh order get applied automatically when I already recorded it?
      Thanks in advance!
    • Saumadeep
      Hi Tim,
      This feature is described in the Ansys Help Link: Selective Meshing (ansys.com), in the section "Using the Mesh Worksheet to Create a Selective Meshing History".
      Also Check this link: Mesh Order Worksheet (ansys.com)
      Saumadeep Choudhury
    • Tim Dietl
      Thank you for your answer! But I couldn't find an answer to my question in the links. I have a working mesh order on the worksheet which works in the mechanical but I am not sure if it gets applied when i start calculations from the parameter set. Do you know what I mean? Or is it not possible in general?
    • Rahul Kumbhar
      When you click on Mesh object in the tree, you should see a worksheet with meshing steps as shown below: In this case, mesh will be generated using the steps. Else, you have to manually define the Named Selections and add them in the worksheet.
    • Tim Dietl
      Okay, thank you!
Viewing 4 reply threads
