Mesh problem. Help please
    • manmorcan
      Dear collegues,
      I am doing my pre-doctoral project working simulating a kayak.
      The problem I got is that, when I try to mesh, I got this:
    • Rahul Kumbhar
      nHere are some suggestion.nUse refined mesh sizing. nUse curvature size functionnturn on defeaturing and use defeature size bigger than thin faces so that it can ignore the sliver faces.nInsert Virtual topology object in the tree. Select the body, right click and generate virtual cells. It may simplify face representation if there are problematic faces.n
    • peteroznewman
      nDid you manage to close the surface model and get a solid body for the kayak before you created the Enclosure for the Fluid Domains?nDid you split the Fluid Domains at the waterline? That plane could also split the kayak.nThen you can use Shared Topology to put the kayak pieces back together.n
    • manmorcan
      Dear Rkumbhar,nit was due to the solid.nnI fixed it in a design program and then introduced it again in Ansys and It worked!Thanks!!n
Viewing 3 reply threads
