March 18, 2020 at 6:38 pm
TomosHughes27
SubscriberHi,
I'm having some mesh quality issues when generating a 3D simulation of a FS car. This is the result I get when I evaluate the quality:
Minimum Orthogonal Quality = 2.05924e-04 cell 61404 on zone 3 (ID: 61405 on partition: 0) at location ( 2.98001e-01 1.21735e-01 2.38366e+00)
(To improve Orthogonal quality , use "Inverse Orthogonal Quality" in Fluent Meshing,
where Inverse Orthogonal Quality = 1 - Orthogonal Quality)
Warning: minimum Orthogonal Quality below 0.01.
Maximum Aspect Ratio = 1.60438e+03 cell 61638 on zone 3 (ID: 61639 on partition: 0) at location ( 4.34346e-02 1.48814e-01 2.38796e+00)
Do you have any recommendation on the quality of the mesh I could do to improve this?
Thanks,
Tomos.
March 19, 2020 at 8:06 am
Keyur Kanade
Ansys EmployeePlease select orhtogonal quality in meshing. then you can check where are those elements. please see following video to locate bad cells.
https://www.youtube.com/watch?v=AzvPxjNyr3w
once you locate the locations, you will need to do mesh or geometry modification.
please do geometry modification if it has sharp angle or small faces or tangency etc.
in meshing you can change the face or edge sizing to reduce mesh skewness.
there are many posts regarding mesh quality on this community. please search.
Keyur
- The topic ‘Mesh Quality’ is closed to new replies.
2943
970
857
599
591
© 2025 Copyright ANSYS, Inc. All rights reserved.
