Preprocessing
Preprocessing
Mesh quality is not good with inflation layers
    • Hqureshi7
      Dear Experts,
      I have created a mesh of fluid domain around turbine in design modeler mesher CFX. I have not applied inflation layers around the blades and hub. The mesh quality as SKEWNESS shows maximum value of 0.85 as shown in the images attached.
      But when, I apply inflation layers around the blades and hub, the quality of mesh decreases and inflation layers produced are not of good quality.
      Please help me on this.
      Thanks
    • Hqureshi7
      Inflation layers using first layer thickness as:
      But the quality of mesh is bad:
      Please help me experts.
      Thanks
    • Keyur Kanade
      min orthogonal quality should be above 0.1.
      check for inflation
      for quality check
      also search community. you will find plenty of posts on inflation and quality.
      Keyur
