August 15, 2018 at 2:08 am
aCVP
SubscriberHi all - I was able to successfully mesh a heart from a CT scan using the "shrink wrap > convert to solid" method in SpaceClaim. However, whenever I add inflation, the mesh quality vastly reduces (on occasion, I will get a "stair-stepping" error). I've included pictures for comparison.
I've played around with the inflation settings (including changing the gap factor) per the user manual + tutorials, but I can't seem to improve the mesh quality.
What can I do to improve the mesh quality after adding inflation?
Thanks!
August 16, 2018 at 2:18 am
Karthik R
AdministratorHello,
Could you please elaborate the nature of your analysis? Are you solving laminar or turbulent flow in this geometry?
What are your settings for the inflation layers and what is the maximum skewness you are getting?
I am attaching a playlist of videos here which take a deep dive into some inflation techniques on Ansys WorkBench meshing.
I hope this helps.
Thank you.
Best Regards,
Karthik
August 17, 2018 at 6:04 pm
aCVP
SubscriberHi - thank you for your response!
My major problem is how do you know when you have enough inflation layers? I am modeling blood flow within a heart.
A Fluent tutorial for Cornell said that your layer thickness should be 1/10th of the diameter of your inflow - however, they did not give any explanation as to why. Is this standard?
Thanks.
August 31, 2018 at 10:20 am
Keyur Kanade
Ansys EmployeeHello,
For improving mesh after prism generation, you can use Fluent Meshing.
In WB Meshing please export .msh file from File --> Export
Start Fluent in mehsing mode. Read .msh file. Go to Mesh --> Auto Node Move.
Select all boundary zones and click apply.
On prism layer thickness: it depends on what y+ you are targeting, what velocities you are using etc.
In general 5 layers of prism layers should be enough for regular flows. Please try to reach aspect ratio of 5-10 for first prism layer.
Keyur
August 31, 2018 at 12:40 pm
Ansys EmployeeThe other thing to check is where the poor cells are. With scan derived geometry you can get spikes and crevices which persist through the skin process. It may be you need to refine the surface mesh in this area.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2706
2138
1355
1144
462
