Mesh refinement
    • Kampanat Cheng
      Good morning,
      I have a problem that when i refine the mesh at the critical area of my design the max stress is multiplying so I am not sure that which one is correct With Refinement or Without refinement both average element quality is almost the same. I am not sure if it is stress singularity because i have already fillet the corner.
      Hopefully somebody can help. Thank in advance
      max stress with refinement
      The max stress when i suppress the refinement.
    • Aniket
      Did you check the link Erik provided on your previous question on the forum here?
      -Aniket
    • peteroznewman
      Refinement on the surface can be set to 1, 2 or 3.
      Reply with the peak stress for no refinement, refinement 1, 2 and 3.
      Look at the difference between each successive value of peak stress.
      Are the differences getting smaller with each higher level of refinement or are they getting larger?
