October 9, 2018 at 10:19 am
October 9, 2018 at 10:46 am
Naresh Patre
Ansys EmployeeHello njakimovska,
You need to assign Edge Sizing with appropriate biasing to refine the mesh. Check out below video on edge sizing and biasing.
October 9, 2018 at 10:54 am
October 9, 2018 at 11:09 am
Keyur Kanade
Ansys EmployeeYou may need to slice the face at these locations to get edges. Then you can use those edges to give sizing.
Keyur
October 9, 2018 at 11:20 am
October 19, 2018 at 12:14 pm
njakimovska
SubscriberHi thanks for your reply, I split those faces and created the mesh. However,
when I name the outlet of my nozzle I get an error in the setup saying "cannot change surface body to fluid. They are different kinds."
Any suggestions on how I can fix this?
October 19, 2018 at 12:56 pm
Keyur Kanade
Ansys EmployeeYou can change it to Fluid in solver.
Keyur
October 19, 2018 at 1:48 pm
Karthik R
AdministratorHello
Is this error in meshing or in the solver? Could you please post a screenshot?
Thank you.
Best Karthik
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2614
2088
1321
1108
459
