April 27, 2023 at 7:16 am
April 27, 2023 at 10:44 am
Aliaksei Trukhnou
SubscriberClean mesh, select bottom body, generate mesh on it first (if it will be not automatic sweep after meshing, you can use method/sweep method/ and change Srt/Trg selection to Manual Source and Target). Than use global generate mesh. I suppose it will be good. If not, repeat it with your rebars and upper volumes.
Or try to use MultiZone Method
April 27, 2023 at 11:24 am
Nanda Veralla
Ansys EmployeeHello Hasan,
I was able to generate a similar mesh what you're trying to acheive by using body sizing, to get a finer mesh adjust the element size accordingly.
Nanda.
April 27, 2023 at 11:33 am
Aliaksei Trukhnou
SubscriberYou have no common area between volumes, thats why you do it by body sizing, but you need contacts between each volumes. In question above i think it share (merge) structure:)
April 27, 2023 at 11:31 am
Hasan İlker ÇELİKER
Subscriberthanks Aliaksei
April 27, 2023 at 11:34 am
Aliaksei Trukhnou
Subscriberu r welcome:)😎
3345
2471
