November 5, 2018 at 3:18 pm
PaulM
SubscriberHey,
I'm new to this forum so I hope this is in the right category. I'm currently modelling a helical gear pair in Static Structural (Ansys 19.1) to find the contact stresses on the teeth under a certain load. I'm also interested in the shear stresses just under the surface of the teeth, therefore I added the Inflation option to my mesh. However this option greatly increases the element count in my model. I attached a picture to show my current mesh. Depicted there is a section cut through both gears, to show the mesh on the inside.
I could of course just reduce the layer count of the inflation, but I'm curious if there is a better option to get a finer mesh on the inside. So the question would be if there is a better alternative to inflation to more finely mesh my parts just under the surface? Or is there another method to reduce the element count?
Regards
Paul
November 5, 2018 at 3:58 pm
Ansys EmployeeIf the gear is helical can you sweep the mesh down the length of it?
November 6, 2018 at 11:29 am
PaulM
SubscriberThanks for the fast answer, I'll try to do that and report back.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1347
1118
461
