September 18, 2018 at 7:29 pm
meganhigley11
SubscriberI created a fairly large 2-D model, input the number of divisions on the edges and mesh controlled all the faces, but when I go to update the mesh or generate a mesh on the entire part, the mesh fails. I'm now essentially meshing it 4 faces at a time, but even that is taking hours to generate for each selection. Has anyone encountered problems like this and what was the solution?
September 18, 2018 at 11:32 pm
klu
Ansys EmployeeHi,
Can you please take a couple screenshots of your geometry, mesh global settings, size controls, mesh methods, etc.?
September 19, 2018 at 9:56 pm
September 19, 2018 at 11:54 pm
klu
Ansys EmployeeHi,
Thanks for sharing these pictures. I am not able to test on my end so I cannot tell the exact solution. However,
1. Would you please check if all faces are mappable? If not, please modify the geometry accordingly.
2. Would you please check if any edge or face is over-defined, i.e., more than one methods or sizing controls are added to a single entity?
3. It seems to me the geometry has symmetric structures. Is it possible to mesh a quarter of it and apply periodic conditions in the solver?
4. If the geometry is symmetric but the physics is not, please refer to links below for tips to mesh repetitive geometries.
Thanks.
September 25, 2018 at 5:05 am
Keyur Kanade
Ansys EmployeeIf you have selected many edges or faces in just one local sizing control then it may take time to mesh a single part as it tries to compute sizing on all edges defined in sizing. You can use different edge sizing for different edges. Please try to use one edge sizing for say 10 edges only.
Keyur
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1345
1118
461
