July 10, 2018 at 9:15 pm
José Mantovani
SubscriberHello friends!
I'm simulating a 3D finite wing with the flow domain seen in the image below.
But, when I generate the mesh the result shows some elements / cells that seem to get into the wing (see the another image), how do I correct this?
Notice that the Defeaturing Mesh feature is turned off.
Thanks!
Mantovani.
July 11, 2018 at 12:11 am
klu
Ansys EmployeeHi Jose,
Basically the mesh size is a bit large to fully resolve the leading edge curvature. Therefore reducing the local mesh size would help. You might decrease the value of Curvature Normal Angle and/or apply local sizing control (use a small mesh size) at the leading edge region. Thanks.
July 11, 2018 at 11:29 pm
José Mantovani
SubscriberI will try! Thanks for help and opportunity!
Mantovani.
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5414
3391
2471
1310
1022
