Mesh the cross section of a beam in ANSYS Mechanical
    • TomPhemmy
      In ANSYS Mechanical, the default cross section mesh for beams with circular cross section is 8 divisions along the circumference and 2 divisions along the radius as shown below :
    • Rahul Kumbhar
      I assume you are okay using APDL commands In Mechanical. You can insert command object under the line geometry and add the coomands to change the secdata.
    • TomPhemmy
      thank you for this information. I have noticed that this works. But why does ANSYS Mechanical not render the new section like APDL does?
    • Rahul Kumbhar
      The reason is these commands are executed while solving in background not in GUI.
    • TomPhemmy
      Good to know; thank you.
Viewing 4 reply threads
