May 20, 2022 at 8:47 am
May 20, 2022 at 10:14 am
dinhan0394
SubscriberAfter make the contact between surfaces, you need to re-generate mesh and will get mesh on surface of rigid body.
May 20, 2022 at 12:05 pm
Emperor
Subscriberthank you for the answer, it's the solution
best regards
- The topic ‘Mesh the face of a rigid body’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8834
4658
3159
1688
1482
