January 12, 2018 at 9:24 am
Hassaan
SubscriberI wanted to know which type of mesh would be suitable in ansys workbench to create a mesh of human bones (knee joint). I require a mesh type which also requires less computational power. Thank you for your help in advance.
January 12, 2018 at 12:38 pm
SubscriberIf you make the bones hollow and leave out the very weak spongy center and only have geometry for the thin compact bone at the surface, you will have a large reduction in model size and the time to solve will be much less.
See the CT image of a knee in this post.
January 12, 2018 at 1:39 pm
Hassaan
SubscriberIs tetrahedron a good choice for the meshing the bones? As the bones have highly irregular surfaces, the hex dominant meshing was giving errors.
January 12, 2018 at 3:55 pm
Raef.Kobeissi
SubscriberTetrahedral mesh(unsteuctured mesh) for structural mechanics should not be a problem it is not as sensitive as in CFD.
Peter, please correct me if I am wrong. -
January 12, 2018 at 4:06 pm
SubscriberYes, tetrahedral elements are okay for this mesh since the deformations will be small. Brick or hex meshing is very helpful when deformations are large such as with the incompressible rubber in this post.
Some researchers are using hex meshes.
January 17, 2018 at 7:25 pm
Hassaan
SubscriberThanks all for your replies.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1347
1118
461
