November 29, 2017 at 7:25 am
kiranczende
SubscriberThe mesh component in mesh requires user input before it can be updated
kiranczende
SubscriberI am getting error message while updating the mesh
November 29, 2017 at 12:06 pm
SubscriberPlease post a screen snapshot of the Mechanical Outline and Geometry window.
November 29, 2017 at 1:10 pm
kiranczende
SubscriberThank You very much for your reply.
I able to get the solution. I think the problem was with the geometry. but still I will send you the screen shot.
November 30, 2017 at 12:24 pm
Raef.Kobeissi
SubscriberIt would be nice to have a picture and show how you resolved the problem, thanks kiranczende.
December 5, 2017 at 5:30 am
December 5, 2017 at 5:53 am
kiranczende
Subscriberhopefully i think the i have got the error.
i have made a line at the center and forget to suppress it.
but when i suppressed it the mesh update was successful
December 5, 2017 at 8:36 am
kiranczende
Subscriberi projected a line to divide the geometry in two parts. While doing this i forget to suppress the line which was creating this error
December 5, 2017 at 12:55 pm
SubscriberThanks for the update. I usually use a plane and a slice operation to divide geometry into two bodies, and put the bodies into a new part.
Next time you need to post a screen snapshot, attach the the file rather than placing the image inline because the website reduces the resolution to fit a large image in the small space of the discussion window, making the image illegible.
December 5, 2017 at 1:44 pm
raul.raghav
SubscriberAs peteroznewman mentioned, a plane and a slice operation is really convenient to divide geometries. It provides you the ability to divide the geometry in XY, YZ & XZ directions with one defined plane. And it does not introduce additional lines or surfaces that you might have to suppress otherwise. See attached screenshot for reference:
December 5, 2017 at 4:15 pm
kiranczende
SubscriberThank You very much for your suggestion peter and Rahul.
I will take care of this from next time onwards
December 6, 2017 at 5:06 am
kiranczende
SubscriberI am trying to analyse shock tube.
my y velocity does not converge. What can be reason?
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2642
2110
1335
1112
461
