September 16, 2018 at 4:20 am
ahmadzaki
SubscriberHello,
I was reading several papers related to wind flows around building structures and I found that they presented their meshing techniques (refinement and type) on the surfaces of those building models and grounds as shown in the following figures (coursey of Blocken et al. 2007 and Van Hoof and Blocken 2010 respectively). I'm using Design Modeler, the standard Ansys Mesher, and Fluent. So I would like to know how to visualize the mesh in the manner shown below?
Thank you for your support.
Ahmad
September 17, 2018 at 10:13 am
Ansys EmployeeYes, it's a good way to display surface mesh, I'd do that sort of image in Fluent. I also suggest using the Section Plane tool (with full cells) in Meshing to view the volume mesh.
September 17, 2018 at 10:40 am
ahmadzaki
SubscriberThank you for your reply and I'm very sorry, I realized that my question was not clear (I edited it). I wanted to know how to visualize the mesh in the manner shown in the attached figures (from the papers I've been reading)?.
September 17, 2018 at 12:45 pm
Ansys EmployeeI was wondering! Thanks for clarifying.
In Fluent use the mesh display (Post processing tab), and show edges & faces on the faces of interest. You may want to alter some colours and turn lights on (View tab). Do NOT display on surfaces labelled interior, default-interior, fluid or solid (or names like these) as they probably contain all of the facets for the 3d volume and tends to take a long time to render.
September 18, 2018 at 2:25 am
ahmadzaki
SubscriberThank you for your reply and concern. Yes it worked.
May 6, 2020 at 2:41 pm
ns778
SubscriberHello, how could I accomplish this in CFX?
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
