September 2, 2019 at 5:01 pm
dreamyjyh
SubscriberHello,
I'm using Discovery AIM R19.2 for my simulation.
When I click to show mesh, I can only see the mesh without geometry surfaces as shown below. I tried multiple ways (e.g. importing different geometry files, create a geometry directly on Ansys, going through the Options under the Tool), but none worked.
Below is a type of meshed view (the typical view) I want to see so that I can redefine the meshes.
Does anyone had the same issue? Please help.
September 3, 2019 at 9:07 am
Ansys EmployeeCan you check for wireframe options in graphics. I don't use Discovery but that looks like a wireframe mesh: you probably want surfaces/solids.
September 3, 2019 at 6:40 pm
dreamyjyh
SubscriberHello,
When I click "Show Mesh," pretty much all options all disabled, and I do not see the option for wireframe <-> surface/solids.
When I click "View," "Refresh" is only option I see.
Under the "Tools" -> "Option", I checked all the options, but there was no function changing wireframe <-> surface/solids.
September 5, 2019 at 3:17 pm
Sandeep Medikonda
Ansys EmployeeThis looks like it could be graphics card related. Can you update the graphics card driver directly through Nvidia (or AMD)?
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2588
2080
1315
1108
459
