Ansys Free Student Software
Mesher failed to mesh topological edges
    • Md Minal Nahin
      Hi, I am trying to mesh the following geometry using Match Control
      However, I am always getting the error: Mesher failed to mesh topological edges.
      Does anyone know any solutions to this?
      Thanks,
      Minal
    • peteroznewman
      Please show the full geometry and where you chose to slice out the section. If you don't have the identical topology on both faces of the section, match control won't work.
      If you would like to put a Workbench Project Archive file .wbpz  (NOT .wbpj) up on a file sharing site such as Google Drive, OneDrive or Jumpshare, you can put a link to that file in your reply and I will take a closer look. Make sure to create a link that anyone can download.
      When you reply, say what version of ANSYS you are using.
    • Md Minal Nahin
      Hello Peter,
      Thanks for your reply. Here is the google drive link: https://drive.google.com/drive/folders/11BA9Lnq2VwJBZrJGglQZBwSZx_6_Dcff?usp=sharing
      And, the version is ANSYS 2022 R1.
      Thanks in advance!
    • peteroznewman
      From the Ansys Help Manual
      1. In the Details View, select Cyclic as the Transformation type and a coordinate system with its z-axis aligned to the axis of rotation for the geometry.
      Create a new Coordinate System but rotate 90 about Global Y to put the Z-axis along the axis of rotation and it will mesh without error.
    • Md Minal Nahin
      Wow! That works! Thanks a lot, Peter!
Viewing 4 reply threads
