November 10, 2019 at 3:21 pm
Giri
SubscriberHi,
I tried to create a volume mesh using the watertight workflow. When I created using the smooth transition offset method I am getting an orthogonal quality of 0.36. Where when I generated the mesh using the uniform offset method, I am getting an orthogonal quality of 0.
I am not able to figure out where I am making a mistake. Can someone please help me solve this?
BTW when I enter the first cell height under the uniform offset method am I supposed to specify in meters or millimeters?
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5290
3311
2469
