May 24, 2022 at 8:32 am
May 24, 2022 at 9:49 am
SubscriberIs there a material change for the different color bands? If so, you can't avoid a small angle. But if there is no material change, then merge the gray face with the brown face and you will have the same condition as you have on the other end of the blend, an element that has a larger angle.
May 24, 2022 at 10:00 am
tjansysehv
SubscriberUnfortunately there is a material change between those color bands
3744
2573
1793
1236
594
