March 24, 2022 at 5:58 pm
BlackDranzer
SubscriberHi,
I am pretty new to Ansys and I have rather simple problem.
I want to mesh a cube so that the mesh is finer at one wall. I care about that most of the elements were cubes. Currently, I use the sweep method but I get cuboid elements at the top of the cube. I am using face sizing to make smaller elements. I know that using the hex dominant method is pointless as the mesh will be used to test the behavior of a water drop in Fluent.
This is what my mesh is looking like right now:
March 25, 2022 at 2:54 amKeyur Kanade
Ansys EmployeeSame post under preprocessing category which is replied.
So closing this duplicate.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2616
2096
1321
1108
461
