March 24, 2022 at 5:38 pm
BlackDranzer
SubscriberHi,
I am pretty new to Ansys and I have rather simple problem.
I want to mesh a cube so that the mesh is finer at one wall. I care about that most of the elements were cubes. Currently, I use the sweep method but I get cuboid elements at the top of the cube. I am using face sizing to make smaller elements. I know that using the hex dominant method is pointless as the mesh will be used to test the behavior of a water drop in Fluent.
This is what my mesh is looking like right now:
March 25, 2022 at 2:53 amKeyur Kanade
Ansys EmployeePlease use sweep method. Please use edge biasing to get finer mesh at walls.
Please go through help manual for more details
Descriptions of Local Sizing Control Options (ansys.com)
Regards Keyur
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
