October 11, 2018 at 9:33 am
fa-ri
SubscriberHello Everyone,
I'm working on flow past a 4-rotor drone.
I meshed the geometry using curvature size function and I have a tetrahedrons mesh method. I have attached a picture below,
I ran the simulation and used mesh motion for each rotating volume.
I get " negative cell volume detected in dynamic mesh "so
I reduce the time step but during of my simulation I saw the following error
"floating point exception".
I would be really grateful if anyone could help me
Thank you
With regards
October 11, 2018 at 9:43 am
Ansys EmployeeYou've made the first sensible step by reducing time step, but I think if you're modelling a drone you'd be better looking at using sliding mesh as it's a fairly well defined rotating zone.
October 13, 2018 at 3:32 pm
fa-ri
Subscriberhello rwoolhou
Thank you for your response.
I attached some pictures of my simulation. Is the mesh acceptable?
fa-ri
October 15, 2018 at 6:05 am
Naresh Patre
Ansys EmployeeThere is very high cell jump at the interface. You may also want to reduce this cell jump by refining the mesh at the interface for outer body.
October 15, 2018 at 2:40 pm
Ansys EmployeeI'd also look at increasing the diameter of the zone surrounding the blades, it's possible the mesh is getting twisted there too. Try and get 2-3 blade widths between the tip and the interface.
November 7, 2018 at 9:01 am
fa-ri
It was helpful.
With regards
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2706
2142
1355
1144
462
