June 26, 2019 at 7:00 am
daveberutu
SubscriberHi Everyone, I am modelling a inconel 625 tube that use to transport fluid from the surface to the production well with depth 6200ft to see the stresses happen on the tube.
I have some trouble on meshing and modelling this very" long tube. The spesification is
outer diameter : 0.375"
thickness : 0.00625"
Length : 6200 ft
Can you help me how to solve this situation?
Your help will be much appreciated.
June 26, 2019 at 10:31 am
Ansys EmployeeGiven the dimensions wouldn't a shell model make more sense? Given the cell count limits I'm not sure you'd be able to mesh it with the Academic/Student versions.
June 26, 2019 at 11:59 am
SubscriberI agree with rwoolhou. Go back the the Geometry editor, and create a Midsurface from the solid body. Then just mesh that surface body.
June 27, 2019 at 4:59 am
daveberutu
SubscriberThank u very much. I've made some progress on my model. But now, I meet new problem, I can't differentiate pressure load from external and internal tube because in my case there are fluids that flow from inner and outside tube. How can I solve this problem?
July 1, 2019 at 3:23 am
daveberutu
SubscriberHow can I differentiate external pressure (that works on outer face tube) & internal pressure (that works on inner face tube) on this shell mode? What I can model is only the internal pressure (Caustic pressure) but the steam pressure that works at the outside pipe, I still can't figure it out how to model it.
July 1, 2019 at 10:29 am
SubscriberFor a shell model, you have to apply the difference in the inside and outside pressures to the face.
July 1, 2019 at 2:38 pm
daveberutu
SubscriberHow can I apply the difference pressure in shell mode? I can't click the outer face of the tube in shell mode. Just inner face can active
July 1, 2019 at 3:19 pm
SubscriberIf the inside pressure is 300 Pa and the outside pressure is 200 Pa then the difference is 100 Pa and you want that directed outward from the tube.
Pick the tube surface and assign 100 Pa and look at the arrow. If it points outward, you are done, if it points inward, change the value to -100 Pa and it will point outward.
The surface normal might point inward or outward depending on which CAD system created the surface.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
3744
2573
1809
1236
594
