Photonics
Photonics
Meshing advanced settings in Charge
    • Mariah Ha
      Hi all,
      I would like to have some more details about these specific settings in Charge for meshing (attached in yellow )  .Are they needed in case of curved complex geometries? Is it more efficient to use these settings instead of adding a mesh constraint? What is the meaning of hybrid volume mesh at the bottom , deflection tolerance...
      Thank you.
    • Khashayar Ghaffari
      Thank you for your question. We provide a description of these mesh setting in this article . I think choosing the mesh setting to adjust/focus-on depends on the issue you are facing. In many cases adding a mesh constraint is a good first step for improving the mesh quality, especially if smaller feature size are limited to a smaller area while the overall simulation region is much larger. This allows for the generated mesh to have a better balance where smaller features are resolved, while reducing the consequent increase in simulation time.
      Changing the volume meshing from vertex insertion to hybrid is typically helpful when the solver fails to generate a mesh (sometimes the mesh will get stuck on tesselation) for small lengthy structures (which could be part of a larger system in your simulation). In some cases the hybrid option succeeds to generate a mesh instead of the vertex insertion option
      As mentioned in the documentation, deflection tolerance can be helpful for meshing curved structures by breaking up the curves into multiple linear segments. Another potential workaround for fixing meshing errors for curved structures are simplifying the geometry, for example by using polygons.
      Best regards
  • The topic ‘Meshing advanced settings in Charge’ is closed to new replies.
