September 22, 2023 at 1:48 am
Bruno de Christo
SubscriberI am carrying out a study on Ahmed's body in order to validate another study on external flow.
With a coarser mesh, I obtain satisfactory values, in addition to convergence. But I need greater precision.
Therefore, I was working on refining the mesh, calculating the size of the thickness of the first boundary layer and the Y+.
However, I find it difficult to obtain convergence of results when I refine the mesh. The residual graphs fluctuate a lot, as do the results for Cd and Cl.
Therefore, I would like to know how I can overcome this problem in order to achieve a good quality mesh and convergence of results.
Another issue is that, when I refine the mesh to the calculated values of the initial boundary layer thickness, there are very small cells, making it difficult to achieve good orthogonal quality of the mesh.
If anyone can help, I would greatly appreciate it.
October 6, 2023 at 12:05 pm
Federico Alzamora Previtali
Ansys EmployeeHello Bruno,
If refining the mesh worsens the mesh quality, you could see such behavior. What is your mesh quality for the finer mesh? What type of mesh are you using?
What method do you have for inflation layers?
Please share more details so that we can provide more specific suggestions!
- Stl Model Setup
- Chassis FEA Help
- Analysis Systems Missing from toolbox in Workbench 2023 R2
- Formula SAE Engine intake simulation
- Error in creating enclosure (some bodies could not be subtracted from enclosure)
- Error in Ansys Meshing: “The imprint zone extends outside the target zone”
- Help
- テスト
- Thermal brake disc
- Software choice
8808
4658
3155
1688
1478
