Preprocessing
Preprocessing
Meshing Assembly in SpaceClaim Meshing
    • reinhardt
      Hi eveyone.
      I have an issue when meshing in SpaceClaim which occurs when I mesh parts in an assembly.
      - Is there any option or command in SpaceClaim Meshing where I can keep the mesh of a component unaltered (considering the mesh controls applied), so that when I mesh a new component this new mesh doesn't change the one that already exists?
      Thanks in advance.
      Greetings
    • Keyur Kanade
      As far as I know, it works on top down approach. so keeping unaltered mesh may not be possible.
      Keyur
    • Keyur Kanade
      If you still want that function, suggest you to use workbench meshing.
      Keyur
    • reinhardt
      Hi Keyur!
      Thank you for the answer.
      Greetings!
Viewing 3 reply threads
