Preprocessing
Preprocessing
meshing at contact
    • Bansal123
      Sir I am trying to generate the hexahedral element(SOLID 90) in the vicinity of the contact region (in the circle) with a very fine mesh for Hertzian contact stress modeling and coarse mesh in the rest of the volume. Please suggest me how can I proceed?
    • peteroznewman
      Place a Coordinate System at the contact point. Add a Sizing Mesh control. Select the two bodies, and set the mesh control to Sphere of Influence, select the coordinate system, enter the radius and the element size.
      If this answers your question, please click the Is Solution link below, or ask a follow up question.
    • Bansal123
      How can I apply an element (SOLID 195) in Ansys workbench using APDL Commands? Which element is best for Hertzian contact tress SOLID186 or SOLID 95?
    • peteroznewman
      SOLID186
    • Bansal123
      Sir, Can you please tell me specifically why SOLID 186 is better? Also How to apply it using APDL Commands?
Viewing 4 reply threads
