Ansys Free Student Software
“Meshing editor does not have a valid license”
    • sivakrishna
      I use ansys student 2022 R1 recently downloaded fresh copy with the inbuilt license.
      Since the past few days i have been facing this issue when i try to open meshing or space claim or any other apart from workbench.
    • George Karnos
      Try renaming the %APPDATA%\Ansys\v221 directory to v221.old.
      Now try to run.
    • sivakrishna
      This is the error i see after doing that.
      So, trying the meshing tool also gave the error. "The shared license is not available to perform the Geometry Attach operation".
      Is it for some reason related to the empty space between the username ("siva krishna")? I have created another user with "SK" to check if its working but did not work either.
      I can provide more info if required. Please help me out with this regards.
    • iKay
      Hi I'm a final year mechanical engineering student and my ansys is giving me a headache I will be very grateful if you would contact me on kkoa54@gmail.com
    • Mo_96
      Hello Friend i also had a Problem with Ansys (Workbench). you can see the Error as a Screenshot. I hope someone can help me with this.
Viewing 4 reply threads
