Preprocessing
Preprocessing
Meshing does not show in the Setup Fluent
    • KianaMousavi
      Hi
      I want to simulate airflow passing through some curved surfaces. I defined a fluid domain for it (the big rectangle). I did the meshing and everything looks ok. However, when I go to the setup phase, only the bigger box is showing and the curved surfaces are not inside it.
      What is the problem here? Is the meshing wrong? (I also checked the boundary conditions in the setup, there is inlet outlet etc, except for the curved surfaces.)
    • Keyur Kanade
      first of all you will need conformal mesh.
      for that you need to use sharetopology in design modeler or spaceclaim.
      please check
      Keyur
    • KianaMousavi
      Hi!
      Thank you for your answer.
      Why do I need to use sharetopology? Cause the curved surfaces that I have do not interface with each other
    • peteroznewman
      Did you subtract the bumpy solids from the solid that represents the air?  If you hide the bumpy solids and go to wireframe display, you should be able to see the cavity left in the air by the bumpy solids.
    • KianaMousavi
      Hi!
      Thank you for your reply! I made the subtraction to the geometries and I imported it again. I did the initial meshing, there was an error for failed mesh.
      After this, I inserted sizing and method of tetrahedrons (I haven't updated the meshing yet, as it takes a lot of time and I want to make all the changes before that)
      But I don't know if the error is due to this. Do you have any suggestions?
    • Keyur Kanade
      There is another duplicate post. Pleas use only one post.
      I have replied in the other post.
      Keyur
Viewing 5 reply threads
