January 22, 2021 at 1:49 am
wanhaf12an
Subscriber"The surface mesh is intersecting or close to intersecting, making it difficult to create a volume mesh. Please adjust the mesh size or adjust the geometry to fix the problem."
I am so close to getting this mesh done, only one part is failing. It was created in CREO Parametric and is a boundary blend. This is a ducted fan design with a pattern of a boundary blend for the blades. This error pops up for the originally blended blade only. When I look at the problematic geometry it is one element. What should I do to fix this element? I have no idea what is causing this or how to fix it.
January 22, 2021 at 10:51 am
Ansys EmployeeWere you trying to open meshing or mesh the geometry? n
5454
3419
2473
1310
1022
