Preprocessing
Preprocessing
Meshing error
    • xykilin
      "The surface mesh is intersecting or close to intersecting, making it difficult to create a volume mesh. Please adjust the mesh size or adjust the geometry to fix the problem."
      I am so close to getting this mesh done, only one part is failing. It was created in CREO Parametric and is a boundary blend. This is a ducted fan design with a pattern of a boundary blend for the blades. This error pops up for the originally blended blade only. When I look at the problematic geometry it is one element. What should I do to fix this element? I have no idea what is causing this or how to fix it.
      Check the sizing that you're applying: how does the cell size compare to the size of the gap? n
    • xykilin
      ,I have re-done the partition of the fluid zone and solved part of the problems. But there is one fluid zone unable to generate quadrilateral mesh. Do you know why?nThanks for your assisstance.nn
      Best guess is it's not happy about the node count/edge sizing. Hex mesh is (arguably) better than tets in this application, but I'd be careful with the aspect ratio where you've clustered cells. n
    • xykilin
      Can you explain it a bit more? I don't really understand that.nMany thanksn
      Sizing settings can mean you're trying to create a poor quality mesh as you force a fixed number of elements. A classic example on a rectangle could be 2 cells on one edge and 30 on the opposite side: with one cell between the two edges the mesh won't be very good. nRe aspect ratio and jumps in cell size, I'll refer you to the various courses available on here and (as an example) the Cornell online course. n
Viewing 5 reply threads
