July 17, 2019 at 3:34 am
July 17, 2019 at 11:06 am
Gaurav Sharma
SubscriberHi RD
There appears to be a problematic region in your geometry which seems to be causing troubles for the mesher. It is difficult to provide precise solution without having a look at the model, but as a general suggestion, you may use the repair options to clean the geometry and that would hep mesher to mesh the model efficiently.
You may also right click on the error "Mesh requires attention" and a dropout will give you option to select location. This will help you locate the problematic region of the geometry, which you can thereafter improve using repair options.
Please give it a try and do let me know if any further assistance is required.
Thanks & Regards,
Gaurav
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Unexpected graphics error
- loss of user settings
- Dwg export error
- Can’t see license on online account
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- problem to access on the spaceclaim help
- Unsymmetric result
3694
2564
1765
1236
592
