Preprocessing
Preprocessing
Meshing error on ducting
    • NathanielChong
      I am trying to run airflow simulation in a room that is ventilated through ducting. When I tried to generate the mesh on the room, I was not able to produce viable meshing on the whole ducting system. Could anyone lend me your knowledge to successfully generate the mesh. The model is attached below. Any input is appreciated.
      Thank you and Regards,
    • peteroznewman
      nI provided some guidance in this Discussion: https://forum.ansys.com/discussion/25734/geometry-preparation-for-cfd#latestn
    • NathanielChong
      Thank you. Will read up on it.n
