August 7, 2018 at 9:59 am
KumarVaibhav
Subscriberhey i am unable to generate the mesh of a CAD with features.Can someone tell me how to fix it?Pls mesh it in ansys and tell me what operations one need to apply?Pls help.Tahnks in advance.CAD attached
August 7, 2018 at 10:44 am
Naresh Patre
Ansys EmployeeHello Kumar,
What physics are you trying to solve? Based on your requirement, select appropriate preference (Mechanical, CFD, etc.) as shown below. Then try meshing the model with default mesh settings. If it is a CFD problem, try generating mesh with default settings and curvature sizing function. If the mesh is still failing, please review the geometry either in Design Modeler or SpaceClaim Direct Modeler for any problems and repair the model.
August 7, 2018 at 11:32 am
Sandeep Medikonda
Ansys EmployeeKumar,
There are numerous resources on youtube (from ANSYS and Channel Partener) that can help you get started:
~Sandeep
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1349
1118
461
