March 12, 2021 at 3:09 am
Priscilla
SubscriberHi all,
May I get some help on below meshing failure turbine? Thank you.
March 14, 2021 at 4:12 pmpeteroznewman
SubscriberMarch 15, 2021 at 4:10 amKeyur Kanade
Ansys EmployeeThis is very generic error. This could be due to geometry problem or due to wrong mesh sizing. Can you please check following? nPlease check geometry in SpaceClaim. Select geometry in structure tree --> Use right click --> Select Check Geometry. The geometry should be error free to proceed. If geometry has any errors, please modify/recreate geometry at those places.nPlease give body/face/edge sizing so that mesh has sufficient mesh density and resolve important features. nFor the error, please use right click on the error and click on 'problematic geometry'. This will highlight geometry which is failing to mesh. You will need to modify geometry at this location or change mesh sizing. nIf your meshing has special controls like periodicity, please check if those are correctly defined. nI assume you have a single cylindrical face with only that one vertical edge as shown by Peter. If you want to remove that edge, you may need to split the face first and then use VT to merge two faces.Regards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynnViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1347
1118
461
