August 16, 2018 at 8:55 pm
Hamza
SubscriberHi, I made a drawing of an ROV as solidworks assembly and saved it as a part, combined it as one body and saved it as iges file format, and imported it to design modular, made an enclosure, did the boolean subtraction and then saved the project.
My problem is with opening the mesh tool: Whenever I try to open it this error appears : Unable to open file C:UsersHamza Ghaleb3_filesdp0globalMECHFFF.mshdb. Unable to get model.
Can someone please help me ?!
August 17, 2018 at 1:56 am
Sandeep Medikonda
Ansys EmployeeHamza, are you able to open the IGES file in SpaceClaim? Also, Can you confirm if this is not a file permission error and that a file exists at that location?
If everything looks ok, see if it helps to do this. Close ANSYS completely, Go to this folder from the file manager:
%appdata%ansys
and rename the folder with the version of ANSYS you are using, say, v191, to something else like v191.old. Then relaunch ansys and try again.
August 17, 2018 at 2:42 pm
Hamza
SubscriberHello Sir.
I tried to open the IGES file on SpaceCLaim and it worked, I also gave ANSYS folder full permission and made sure that a file exists at that location.
What I couldn`t do is to find the appdata folder. Sorry this might seem naive but I couldn`t find the folder on my computer ( Used Windows Search ).
Can you give me the details of how to teach that file ? -
August 17, 2018 at 3:06 pm
Sandeep Medikonda
You would do it through a file explorer:
but it should have worked from windows search as well. %appdata% is an environment variable and maybe it is not properly defined on your computer? What OS and version are you using? See if you can go to this location and try the same:
C:UsersHamza GhalebAppDataRoamingAnsys
~Sandeep
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2616
2098
1323
1108
461
