Preprocessing
Preprocessing
meshing in fluid fluent
    • tomar
      i have created a solid plate with fin and created a fluid domain.
      but i cant do meshing, it is showing some error.
      i have attached file below
      can someone please resolve this issue
      Please can you post images into the text: staff are not permitted to open/download attachments.
    • tomar
      in this domain i am facing meshing error , you can check i have attached both image ( geometry and domain meshing error )
    • Mdijo
      I have imported a SOLIDWORKS drawing into ANSYS R1 2019 academic version. Its a multiphase domain simulation but the workbench does not give me an opportunity to identify and select the solid and the fluid from the diagram. Now it treats everything as solid and the meshing is wrong. What can I do to have a good mesh differentiating the solid and the fluid?
      Looking at the DM image you've not created a multi-body part so will have a non-conformal mesh: it'll work but isn't ideal.  I can see that the mesh has failed; what error is reported inside Meshing?
Viewing 4 reply threads
